is there a programming error in r.tiff.in.?
Sabrina Agnesi s.agnesi at tin.it
Thu Apr 6 03:39:56 EDT 2000
Hi Peter,
Actually I am using r.in.tiff module, but I haven't really solved the problem!
In fact what I have done is install RedHat 6.0 and GRASS ver4.3 (at the
moment I don't need floating point capabilities) and it works!
I still don't understand if its a libraries mismatch or a r.in.tiff module
bug, maybe both? the problem is that I started to use GRASS and Linux one
mounth ago.
bye
Sabrina
At 16.20 05/04/00 -0230, you wrote:
>Hi Sabrina. I was just wondering if you ever got the r.tiff.in module
>working properly in GRASS and if so what you did to fix the problem?
>Peter Earle
>Biology Department
>Memorial University
>St. John's, NF
>Canada
>A1B 3X9
>On Sun, 21 Feb 1999, Sabrina Agnesi wrote:
>> Hello GRASS comunity,
>> I'm very new to Linux OS and GRASS. I have on my PC Linux (Mandrake7) and
>> GRASS (ver5.6beta).
>> I am attempting to import a tiff file using r.in.tiff command, and first I
>> got a message saying that it could not locate shared library libjpeg.so.6.
>> So in /usr/lib I found libjpeg.so.62.0.0 and created a link to it called
>> libjpeg.so.6. Then I ran ldconfig. Boot the machine and then when I run
>> r.in.tiff I get a segmentation fault error...
>> I check in the mailing list and  realize that I'm not the only one that have
>> this problem,
>> Do you know where I can find the libraries in the net? supposing is library
>> mismatch!
>> Does anybody fix the problem?
>> Thanks
>> Sabrina
