ellipsoid Krasovsky
Andreas Lange Andreas.Lange at Rhein-Main.de
Sun Apr 9 07:54:27 EDT 2000
Elke Friebe wrote:
> Hallo GRASSER,
> is there somebody who has already worked with ellipsoid Krasovsky (
> russian Satellite picture KVR1000) ?
> Any help greatly appreciated...
> Elke Friebe
> (KVR-1000 georeferenced - ellipsoid Krasovsky, projection Gauss-Kruger,
> central
> meridian 11*E)
Hi Elke,
what is your question here? I am no specialist in this, so you should
verify my suggestions.
The ellipsoid Krasovsky is supported by grass (see file
etc/ellipse.table). This is the same as the old topographic maps from
DDR, projection Gauss-Krueger is the same as in germany. Central
meridian 11E is different from the system used by the german
gauss-krueger-system, which uses 6E, 9E, 12E and 15E (2, 3, 4, and 5) as
central meridians. But this should be no problem as far as you do not
need to import other data in your location.
Use this values for your location:
Projection: tmerc, Ellipsoid: krasovsky, Central Parallel 0N, Central
Meridian 11E, Scale Factor at Central Meridian: 1, False Easting 50 000,
Plural Form of units: meters.
HTH,
Gruesse,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de, A.C.Lange at GMX.net
