[GRASSLIST:1206] Re: problem installing GRASS5.0beta in linux RH6.0
Markus Neteler neteler at geog.uni-hannover.de
Fri Dec 1 11:10:24 EST 2000
Hi Elio
On Fri, Dec 01, 2000 at 11:01:31AM -0500, Elio Ramos wrote:
> Hi:
> I am trying to install GRASS5.0beta in my RH6.0 box (Intel version) but
> I'm getting the
> following error message when I try the "make install':
> if [ ! -d /usr/local/grass-5.0b ]; then mkdir /usr/local/grass-5.0b ; fi
> if [ ! -d src/CMD/next_step ]; then mkdir src/CMD/next_step ; fi
> env UNIX_BIN=/usr/local/bin SRC=`pwd` GISBASE=/usr/local/grass-5.0b
> MACHINENAME=`uname -n` /bin/sh src/CMD/generic/CREATE_GMAKE.sh
> mkdir -p -m 755 /usr/local/grass-5.0b
> /bin/sh `pwd`/src/CMD/generic/is64bit.sh
> env GRASSSRC=`pwd`/src GMAKE=`pwd`/src/CMD/gmake5.0 /bin/sh
> src/CMD/generic/GISGEN.sh
> SRC=/home/eramos/temp/grass5.0beta/src
> CMD=/home/eramos/temp/grass5.0beta/src/CMD
> HEADER=head
> ARCH=i686-linux-elf
> GISGEN                              Fri Dec 1 10:03:59 CST 2000
>  GISBASE = /usr/local/grass-5.0b
>  SRC     = /home/eramos/temp/grass5.0beta/src
>  CMD     = /home/eramos/temp/grass5.0beta/src/CMD
>  HEADER  = head
>  ARCH    = i686-linux-elf
> first step: src/display/d.3d
> GISGEN: src/display/d.3d - Fri Dec 1 10:03:59 CST 2000
> /home/eramos/temp/grass5.0beta/src/display/d.3d
>   make -f OBJ.i686-linux-elf/make.rules
> make[1]: Entering directory
> `/home/eramos/temp/grass5.0beta/src/display/d.3d'
> rm -f OBJ.i686-linux-elf/get_inputs.o
> gcc -g -O2   -I/home/eramos/temp/grass5.0beta/src/include  -c
> get_inputs.c
> make[1]: Leaving directory
> GISGEN failure at STEP: src/display/d.3d
> Any ideas??? recommendations???
Which GRASS 5 beta do you use?
And: please send the *full* error message. You may send it personally
to me. To get it again enter:
gmake5 src/display/d.3d
Kind regards
 Markus Neteler
