[GRASSLIST:1213] Re: v.db.reclass
Radim Blazek Radim.Blazek at dhv.cz
Tue Dec 5 15:27:07 EST 2000
> Hello,
> In Grass-CVS, v.db.reclass gives me the following error:
> 'ERROR: category gory invalid'
> after entering the following command:
> v.db.reclass input=world2 output=ref_pop99 table=categories key=grass_id
> rules=/home/mlennert/data/recl.sql type=area title=ref_pop98
> I connected to a Postgresql database via odbc before typing this command. I
> tried via TclTkGrass first and then on the command line, always getting the
> same error.
> Moritz
Is it connection to DB OK? Can you run simple modules like:
db.tables, db.columns, db.select?
Can I see your recl.sql file?
Radim
