[GRASSLIST:1261] Re: Fw: Re: Two more grass5b10 gnats
bob at math.umn.edu bob at math.umn.edu
Wed Dec 13 12:23:14 EST 2000
RGK allegedly wrote:
> ----- Original Message -----
> From: Justin Hickey
> To: bob at math.umn.edu ; grasslist at baylor.edu
> Sent: Wednesday, December 13, 2000 11:34 AM
> Subject: [GRASSLIST:1256] Re: Two more grass5b10 gnats
> Hi Chris
> bob at math.umn.edu wrote:
> > For your enjoyment ...
> > Running grass5 died (linux prompt) and was only fixed by editing
> > /usr/local/grass5/tcltkgrass/script/gis_set.tcl to comment out lines:
> > 706 #if { [string compare -nocase $ver "8.0"] < 0} \
> > 707 #{
> > 708 #    puts stderr "Sorry your version of Tcl/Tk is $ver and is too
> > old for GRASS."
> > 709 #    puts stderr "GRASS requires a TCL/TK version of 8.0 or more."
> > 710 #    puts stderr "Reverting back to text mode interface."
> > 711 #    exit 1
> > 712 #}
> Actually, a better fix is to simply delete the -nocase option (and
> remove the comments :).
That would assume I had a clue, of course.  Thanks, done, and works.  :^)
> > When the GUI pops up, starting the monitor fails because my $PATH is
> > too long for it.  Running d.mon from the grass5 prompt works fine.
> > Perhaps the Tcl/Tk should not worry so much about the size of
> > environmental variables.  If that is possible ...
> Hmmm. I'm not sure what the problem is here, I do not know of any limit
> to the size of environment variables. What is the actual error message
> you get?
Error: Error: Aborting!
Excessive environmental variable length:
'PATH=/a/very/many/paths/all/strung/together/over/9/lines/in/the/popup'
child process exited
abnormally
> Thanks for notifying us of these problems.
You may regret those words, friend.  ;^l
<snip>
Thanks for your time.
Adios,
Chris
C.S. Cornuelle
School of Mathematics/MCIM, University of Minnesota
206 Church St. SE, Minneapolis, MN 55455
(612) 626-8930v, (612) 624-2333f, bob at math.umn.edu
Ferventer Vestite
