[GRASSLIST:1276] Re: tcltk problem with grass5b10
Eric G . Miller egm2 at jps.net
Thu Dec 14 11:13:51 EST 2000
On Thu, Dec 14, 2000 at 08:04:01AM -0700, William L. Baker wrote:
> I too had this same error upon installing under Linux
> Mandrake 7.2.  ./configure fails to find the tcl library
> (tcltk 8.3 is included) for some reason.  After manually
> editing the resulting Gmakefile so that the library is
> correctly identified, then the make install step does
> work and the funny little box etc. go away.  Perhaps
> there's a way to fix the configure script so it finds
> the library right in the future?  This is beyond my
> area of knowledge.
Could you be so kind as to tell me what the paths are to
tk.h and tcl.h under /usr/include/?? and how the libraries are named on
Mandrake /usr/lib/libtk8.3.a ?  You must have the static libraries for
configure to work.
Eric G. Miller <egm2 at jps.net>
