[GRASSLIST:1290] Re: permissions (continued)
Eric G . Miller egm2 at jps.net
Sun Dec 17 20:19:37 EST 2000
On Sun, Dec 17, 2000 at 05:04:33PM -0700, Roger S. Miller wrote:
> What is map at PERMANENT?  This isn't a command syntax I've run across yet.
The @<mapset> syntax allows you to specify a dataset in a particular
mapset (within the same location).  You can only perform read operations
on data not in the current mapset.
GRASS:~> d.rast soils at theFarm
Would draw the raster "soils" in the mapset "theFarm".
Eric G. Miller <egm2 at jps.net>
