[GRASSLIST:1316] Re: Colormode problems on powerpc linux
Allan Hollander adh at rachel.des.ucdavis.edu
Wed Dec 20 20:37:42 EST 2000
I don't think the number of color levels is the issue (I have no problem
with running under 24-bit color).  Rather, d.colormode mode=float seems
still to be needed in order to adjust a color table interactively in
d.colors (i.e. highlighting a category, and having changes to the color
table appear immediately).
-- Allan
On Wed, 20 Dec 2000, Markus Neteler wrote:
> Hi Allan,
> as the GRASS 5 XDRIVER support much more colors than the old 4.x
> Xdriver the d.colormode mode=float is not required any more. We
> should consider to remove it (or improve the error message).
> If you want more than 32768 colors, use the
>     nlev   Number of color levels for each R/G/B
> option of d.mon.
> Hope this helps
>  Markus Neteler
