Multiple processor support
Bernhard Reiter bernhard at intevation.de
Fri Feb 18 05:58:38 EST 2000
On Wed, Feb 16, 2000 at 10:47:24AM -0500, Neal FLanagan wrote:
> A question form a GRASS Newbie:  does grass support multiple processors?
AFAIK GRASS does _not_ support any parallel processing.
As GRASS runs most commands on the shell, the computer can do load
balancing for each started command.
> If so, is this feature require the use of a special flag during
> compiling?  If not, are there plans to support multi processing in the
> future?
To actually make use of more than on processor, you need
task, which profit from running parallel. Most commands in grass
are not written this way. It would be a quite a bit of development
support to parallelise some modules. But if you need a special
module you might get it done pretty fast.
I hope this answers your question.
	Bernhard
Free Software Projects and Consulting 		         (intevation.net)
Association for a Free Informational Infrastructure            (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20000218/f6528ef8/attachment.bin
