NVIZ Scale, Labels & Ruler?
Pierre de Mouveaux p_de_mouveaux at hotmail.com
Mon Feb 28 12:19:51 EST 2000
will I was tracking some NVIZ bugs, some times ago,
I did a "full checck" of the code.
The ruler, scales,  etc.. in NVIZ are all empty
commands.
These commands do work in the SG3D Motif app.
Pierre.
>From: Philip Warner <pjw at rhyme.com.au>
>To: grasslist at baylor.edu
>Subject: NVIZ Scale, Labels & Ruler?
>Date: Mon, 28 Feb 2000 14:09:06 +1100
>MIME-Version: 1.0
>Received: from [129.62.1.18] by hotmail.com (3.2) with ESMTP id
>MHotMailBA83337900B4D82197D4813E01129A8D0; Sun Feb 27 19:16:18 2000
>Received: from host (localhost [127.0.0.1])by ccis01.baylor.edu
>(8.9.1/8.9.1) with SMTP id VAA15826;Sun, 27 Feb 2000 21:11:29 -0600 (CST)
>Received: from ccis08.baylor.edu (ccis08.baylor.edu [129.62.1.2])by
>ccis01.baylor.edu (8.9.1/8.9.1) with ESMTP id VAA31758for
><GRASSLIST at listproc.baylor.edu>; Sun, 27 Feb 2000 21:08:26 -0600 (CST)
>Received: from acheron.rime.com.au (albatr.lnk.telstra.net) by baylor.edu
>(PMDF V5.2-31 #33495) with ESMTP id <01JMEZS4XEZKCQRQ2C at baylor.edu> for
>GRASSLIST at listproc.baylor.edu (ORCPT rfc822;grasslist at baylor.edu); Sun, 27
>Feb 2000 21:08:25 CST
>Received: from oberon (Oberon.rime.com.au [203.8.195.100])by
>acheron.rime.com.au (8.9.3/8.9.3) with SMTP id OAA17777	for
><grasslist at baylor.edu>; Mon, 28 Feb 2000 14:08:01 +1100
>From owner-GRASSLIST at baylor.edu Sun Feb 27 19:17:23 2000
>Message-Id: <2078273.0.5.32.20000228140906.00b06100 at mail.rhyme.com.au>
>Sender: owner-GRASSLIST at baylor.edu
>Precedence: bulk
>X-Sender: pjw at mail.rhyme.com.au
>X-Mailer: QUALCOMM Windows Eudora Pro Version 3.0.5 (32)
>X-Listprocessor-Version: 7.2 -- ListProcessor by CREN
>I am trying to get NVIZ to put a scale, labels or a ruler on a window, and
>I don't seem to have much luck.
>I have used the spearfish database with elevation.dem as my raster later.
>All other options are default. This shows me a wireframe which I can colour
>etc.
>When I make changes in the labels, or scale panels, I see no result on the
>rendering window, despite pressing various buttons.
>Is there something I am missing here? Perhaps someone could suggest some
>simple steps to add a label to a rendered image.
>Thanks in advance,
>Philip Warner.
>Philip Warner                    |     __---_____
>Albatross Consulting Pty. Ltd.   |----/       -  \
>(A.C.N. 008 659 498)             |          /(@)   ______---_
>Tel: +61-03-5367 7422            |                 _________  \
>Fax: +61-03-5367 7430            |                 ___________ |
>Http://www.rhyme.com.au          |                /           \|
>                                  |    --________--
>PGP key available upon request,  |  /
>and from pgp5.ai.mit.edu:11371   |/
______________________________________________________
Get Your Private, Free Email at http://www.hotmail.com
