Easy GRASS 5 question
Andrew E Long aelon at sph.umich.edu
Tue Jan 4 16:18:23 EST 2000
Seems to me that you want to explore r.mapcalc!
Andy
On Tue, 4 Jan 2000 bob at math.umn.edu wrote:
> I'm trying to understand how to use GRASS as a read/write mapping
> utility.  The challenge for me is to learn what to do in order to
> read a pixel from a map layer, process it in some way, and then
> write it back out with a new value to the same map layer.  The on-line
> docs have not yielded the dark secret of this relatively low-level
> operation set.  Could somebody point me in the right direction?  Or
> should I start looking at the source code for some related commands?
> Thanks.  BTW, tangent now compiles, and thanks.
> Adios,
> Chris
> C.S. Cornuelle
> School of Mathematics/MCIM, University of Minnesota
> 206 Church St. SE, Minneapolis, MN 55455
> (612) 626-8930v, (612) 624-2333f, bob at math.umn.edu
> Ferventer Vestite
