Beta 5 and its lockfile
bob at math.umn.edu bob at math.umn.edu
Tue Jan 18 10:03:36 EST 2000
Jim,
Forwarded message:
> From owner-GRASSLIST at baylor.edu Mon Jan 17 09:53 CST 2000
> Message-Id: <1046411238831E79 at webmail>
> Date: Mon, 17 Jan 2000 10:45:37 -0500
> Sender: owner-GRASSLIST at baylor.edu
> Precedence: bulk
> From: jbrowne <jbrowne at liu.edu>
> To: GRASSLIST <GRASSLIST at baylor.edu>
> Subject: Beta 5 and its lockfile
> MIME-version: 1.0
> Content-transfer-encoding: 7bit
> X-Sender: jbrowne <jbrowne at liu.edu>
> X-Mailer: WebMail (Hydra) SMTP v3.60
> X-WebMail-UserID: jbrowne
> X-EXP32-SerialNo: 00002866
> X-Listprocessor-Version: 7.2 -- ListProcessor by CREN
> Content-Type: text/plain; charset="ISO-8859-1"
> Content-Length: 916
> What did I do wrong?
> I've had GRASS5beta4 running since October, I was hesitant to touch it but
> yesterday I uninstalled it and installed beta5. When I tried to run it and
> got:
>    GIS.sh line 23: 1308 Segmentation Fault $ETC/lock $lockfile$$
>    Unable to properly access /home/nydir/.gislock5
> The directory is right and there should be no permission problems. I even
> tried it from root, same thing. As a kludge, I commented out the exit;; line
> in the script. GRASS then started, but exited too fast for me to read any
> messages.
>    I looked at the Beta4 source, and it seems that returning 0 flags a lock
> and 1 is O.K.. The script seems to expect the opposite. I'm going to download
> and check the new source.
>    If this was a bug, and a fix was posted, my apologies. With both the forum
> and the mail archive down, I couldn't check.
>                              Thanks
>                                Jim
FYI I got the same thing, did the same things, etc.  It seems that a bit
of housekeeping is needed in upgrading versions - not so bad, if one knows
about it, but annoying otherwise.
Adios,
Chris
C.S. Cornuelle
School of Mathematics/MCIM, University of Minnesota
206 Church St. SE, Minneapolis, MN 55455
(612) 626-8930v, (612) 624-2333f, bob at math.umn.edu
Ferventer Vestite
