v.in.arc: error reading file
Markus Neteler neteler at geog.uni-hannover.de
Wed Mar 8 13:23:34 EST 2000
Hi David,
this might be related to G_strip commands used there.
Please try if you change G_strip to G_squeeze.
Reason could the the changes from gets to fgets
and related stuff.
Hope this helps (if you get it, please send me
the diffs for the CVS).
  Markus Neteler
 Geographisches Institut   |     Schneiderberg 50
  + Physische Geographie         30167 Hannover, Germany
  & Landschaftsoekologie +       Tel: ++49-(0)511-762-4494
 Universitaet Hannover           Fax: ++49-(0)511-762-3984
On Wed, Mar 08, 2000 at 05:02:30PM +0000, D D Gray wrote:
> Can anyone tell me what is wrong with the included text file[s].
> I am trying to import a simple ungen file set with v.in.arc. But when
> I run v.in.arc with the text file option it doesn't import giving the
> error:
> v.in.arc: Coverage type = polygon
> The LABEL-TEXT file has been scanned. There are 15
> lines in the file and 3 columns in the file
> Working...
> ERROR: Reading LABEL-TEXT or LABEL-POINTS file
> It imports the lines file OK (without the text_in option.)
> The command is:
> v.in.arc lines_in=simple.pol points_in=simple.lab \
>  text_in=simple.txt vector_out=simple idcol=1 catcol=3 type=polygon
> I've tried both GRASS4.2.1 and GRASS5beta6, also with
> an optional 'END' line on each file in all combinations.
> Also it says 15 lines: I count 14. . .
> Any help appreciated.
> D Gray
