GIS.sh and bash
Markus Neteler neteler at geog.uni-hannover.de
Tue May 2 14:37:21 EDT 2000
On Tue, May 02, 2000 at 07:38:43PM +0200, Moritz Lennert wrote:
> That was it, thank you !
> But I believe this info should be "INSTALL" instructions that come with
> the source code.
Thanks Moritz,
I have updated the INSTALL in source code (really, it was missing).
Markus
> On Tue, 2 May 2000, Markus Neteler wrote:
> > On Mon, May 01, 2000 at 07:31:28PM +0200, Moritz Lennert wrote:
> > > Is the old GIS.sh and bash problem solved in 5.0b or do I need to get a
> > > special GIS.sh ? For the moment I get the following error messages when
> > > trying to connect to a location I just created:
> > Hi Moritz,
> > it is solved for GRASS 5.x and 4.2.1 and 4.3. I will remove
> > the message from FAQ.
> > > /usr/local/grass-5.0b/etc/GIS.sh: g.gisenv: command not found
> > > /usr/local/grass-5.0b/etc/GIS.sh: g.gisenv:command not found
> > > /usr/local/grass-5.0b/etc/GIS.sh: GISDBASE: parameter null or not set
> > I guess after compiling you did not run
> > gmakelinks5
> > Cheers
> >  Markus
Dipl.-Geogr. Markus Neteler *  University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494  Fax: -3984
