r.sun
Jaro Hofierka hofierka at geomodel.sk
Wed May 3 07:25:41 EDT 2000
DIETER LEHMANN wrote:
> Hi,
> had problem with r.sun in grass5.beta6
> in flat areas, where aspin=0 and slopein=0 there is no energy
> calculation.
> How can I avoid this?
> Btw. is in grass5 0 no-data like in grass4.2 ?
Dieter,
r.sun works only with cells with 0 (as valid data). Therefore you must run
r.support on your grids with null data and say yes in this prompt:
>  you want to create/reset null file for [your.grid.file] so that
> all cell values are considered valid data? (y/n) [n]
After that, r.sun should work properly.
Hope this helps!
WBR,
J. Hofierka
