Digitizing in GRASS
Alejandro Imass aimass at net-a1.net
Fri May 19 08:38:28 EDT 2000
Justin Hickey wrote:
> If you want to give it a try, I can send the code to you but I would strongly
> recommend that you look through the code to see if it does what you expect.
> It's not too long and is contained in a single file. I also put some comments
> in to describe what the code does.
> Again, I'm not sure if this will help you or not, but you are welcome to try it
> if you want.
Yes. I would like to see this very much.
Thank You,
Alejandro
BTW. Take a look at my response to David and tell me if this is on the same lines
as what you were experiencing. It seems very much so to me, but I could be wrong.
