Digitizing in GRASS Part II
Michel Wurtz - ENGEES/CEREG mw at engees.u-strasbg.fr
Fri May 19 10:04:40 EDT 2000
Michel Wurtz - ENGEES/CEREG wrote:
> If you import your file, you will see that the lines are OK, but
> it's only line (white in v.digit) not area limits (blue in v.digit)
OOOps! it's area limits (those are white) and the topology still exists
because the dig_att file is copied again (both ascii and binary vector
files share the same dig_att directory)
Michel Wurtz    ENGEES - CEREG
                1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
                Tel: +33 03.88.24.82.45  Fax: +33 03.88.37.04.97
