[GRASSLIST:1098] Compiling GRASS5.0beta8 on Alpha (DS-10) Linux
F.Tusell etptupaf at bs.ehu.es
Thu Nov 9 08:08:13 EST 2000
I do get a binary when compiling GRASS, but some ot th functionality
is removed. Problem seems to be lack of library diglib64, which I
cannot find in the sources.
The error.log file follows. Can someone help? Please send a copy of
the answer directly to me, as I am not in this list.
Many thanks.
ft.
Fernando TUSELL                                 e-mail:
Departamento de Econometría y Estadística           etptupaf at bs.ehu.es
Facultad de CC.EE. y Empresariales              Tel:  (+34)94.601.3733
Avenida Lendakari Aguirre, 83                   Fax:  (+34)94.601.3754
E-48015 BILBAO  (Spain)                         Secr: (+34)94.601.3740
PGP: finger etptupaf at bsdx01.bs.ehu.es           http://agesi.bs.ehu.es
--------------  error.log  ------------------
GRASS GIS compilation log:
Wed Nov  8 13:34:09 CET 2000
Module source code not installed: src/libes/vect32/diglib64 (ignored)
Compilation error in module: src/display/d.area (ignored)
Compilation error in module: src/display/d.vect (ignored)
Compilation error in module: src/display/d.vect.cats (ignored)
Compilation error in module: src/display/d.vect.zoom (ignored)
Compilation error in module: src/display/d.what.vect (ignored)
Compilation error in module: src/general/g.region (ignored)
Compilation error in module: src/imagery/i.points3 (ignored)
Compilation error in module: src/imagery/i.vpoints (ignored)
Compilation error in module: src/mapdev/v.alabel (ignored)
Compilation error in module: src/mapdev/v.area (ignored)
Compilation error in module: src/mapdev/v.autocorr (ignored)
Compilation error in module: src/mapdev/v.bubble (ignored)
Compilation error in module: src/mapdev/v.build (ignored)
Compilation error in module: src/mapdev/v.build.polylines (ignored)
Compilation error in module: src/mapdev/v.cadlabel (ignored)
Compilation error in module: src/mapdev/v.clean (ignored)
Compilation error in module: src/mapdev/v.cutter (ignored)
Compilation error in module: src/mapdev/v.db.reclass (ignored)
Compilation error in module: src/mapdev/v.digit (ignored)
Compilation error in module: src/mapdev/v.distance (ignored)
Compilation error in module: src/mapdev/v.extract (ignored)
Compilation error in module: src/mapdev/v.from.3 (ignored)
Compilation error in module: src/mapdev/v.geom (ignored)
Compilation error in module: src/mapdev/v.in.arc (ignored)
Compilation error in module: src/mapdev/v.in.ascii (ignored)
Compilation error in module: src/mapdev/v.in.atlas (ignored)
Compilation error in module: src/mapdev/v.in.dlg (ignored)
Compilation error in module: src/mapdev/v.in.dxf (ignored)
Compilation error in module: src/mapdev/v.in.dxf2 (ignored)
Compilation error in module: src/mapdev/v.in.dxf3d (ignored)
Compilation error in module: src/mapdev/v.in.shape (ignored)
Compilation error in module: src/mapdev/v.in.tig.basic (ignored)
Compilation error in module: src/mapdev/v.in.tig.lndmk (ignored)
Compilation error in module: src/mapdev/v.in.transects (ignored)
Compilation error in module: src/mapdev/v.info (ignored)
Compilation error in module: src/mapdev/v.llabel (ignored)
Compilation error in module: src/mapdev/v.merge (ignored)
Compilation error in module: src/mapdev/v.mkgrid (ignored)
Compilation error in module: src/mapdev/v.mkquads (ignored)
Compilation error in module: src/mapdev/v.out.arc (ignored)
Compilation error in module: src/mapdev/v.out.atlas (ignored)
Compilation error in module: src/mapdev/v.out.dlg (ignored)
Compilation error in module: src/mapdev/v.out.e00 (ignored)
Compilation error in module: src/mapdev/v.out.idrisi (ignored)
Compilation error in module: src/mapdev/v.out.mapinfo (ignored)
Compilation error in module: src/mapdev/v.out.mif (ignored)
Compilation error in module: src/mapdev/v.out.moss (ignored)
Compilation error in module: src/mapdev/v.out.shape (ignored)
Compilation error in module: src/mapdev/v.patch (ignored)
Compilation error in module: src/mapdev/v.proj (ignored)
Compilation error in module: src/mapdev/v.prune (ignored)
Compilation error in module: src/mapdev/v.random (ignored)
Compilation error in module: src/mapdev/v.reclass (ignored)
Compilation error in module: src/mapdev/v.rm.dangles (ignored)
Compilation error in module: src/mapdev/v.rmdup (ignored)
Compilation error in module: src/mapdev/v.spag (ignored)
Compilation error in module: src/mapdev/v.stats (ignored)
Compilation error in module: src/mapdev/v.surf.rst (ignored)
Compilation error in module: src/mapdev/v.timestamp (ignored)
Compilation error in module: src/mapdev/v.to.db (ignored)
Compilation error in module: src/mapdev/v.to.rast (ignored)
Compilation error in module: src/mapdev/v.to.sites (ignored)
Compilation error in module: src/mapdev/v.transform (ignored)
Compilation error in module: src/mapdev/v.trim (ignored)
Compilation error in module: src/mapdev/v.what (ignored)
Compilation error in module: src/misc/m.in.e00 (ignored)
Compilation error in module: src/paint/Programs (ignored)
Compilation error in module: src/paint/Programs/p.map.new/cmd (ignored)
Compilation error in module: src/ps.map (ignored)
Compilation error in module: src/raster/r.binfer (ignored)
Compilation error in module: src/raster/r.combine (ignored)
Compilation error in module: src/raster/r.contour (ignored)
Compilation error in module: src/raster/r.flow (ignored)
Compilation error in module: src/raster/r.flowmd (ignored)
Compilation error in module: src/raster/r.in.shape (ignored)
Compilation error in module: src/raster/r.line (ignored)
Compilation error in module: src/raster/r.mapcalc (ignored)
Compilation error in module: src/raster/r.poly (ignored)
Compilation error in module: src/raster/r.resamp.rst (ignored)
Compilation error in module: src/raster/r.weight (ignored)
Compilation error in module: src/sites/s.out.e00 (ignored)
Compilation error in module: src/sites/s.surf.rst (ignored)
Compilation error in module: src/sites/s.to.vect (ignored)
Compilation error in module: src.contrib/NPS/v.circle (ignored)
Compilation error in module: src.contrib/NPS/v.circle/cmd (ignored)
Compilation error in module: src.contrib/NPS/v.circle/inter (ignored)
Compilation error in module: src.contrib/OTHER/v.in.poly (ignored)
Compilation error in module: src.contrib/PURDUE/s.medp (ignored)
Compilation error in module: src.contrib/PURDUE/s.voronoi (ignored)
Compilation error in module: src.contrib/SCS/vector/v.dump (ignored)
Compilation error in module: src.contrib/SCS/vector/v.make.subj (ignored)
Compilation error in module: src.contrib/SCS/vector/v.mk_stats (ignored)
Compilation error in module: src.contrib/SCS/vector/v.report (ignored)
Compilation error in module: src.contrib/SCS/vector/v.rmedge (ignored)
Compilation error in module: src.contrib/SDTS (ignored)
Wed Nov  8 13:57:19 CET 2000
DONE generating GRASS GIS binary code
--------------- end of error.log ---------------
