[GRASSLIST:1749] RE: New Support Forum
Matt.Wilkie Matt.Wilkie at gov.yk.ca
Tue Apr 17 20:00:58 EDT 2001
Hi Bruce,
> If you've got some suggestions for things you feel are
> important, let us know so we can make the changes.
My biggest problem with online forums is that generally they are an
island unto themselves. If I post a question on the forum, only forum
readers will see it and possibly respond. If the forum is a new one
and not patrolled regularily by talkative veterans it inevitably
turns into a wasteland of unanswered "help me!" pleas which discourages
new users from participating and eventually leads to the slow withering
death of the community.
Secondly, with regards to GRASS in particular, there is a long and
detailed history of problems and solutions from the user community
going back to 1991. (http://www.geog.uni-hannover.de/grass/support.html)
A "New" disconnected support forum throws all that work and knowledge
away. To be truly useful the new knowledge base needs to be rebuilt
which is just plain silly when so much of it already exists.
Ideally the online forum and the mailing list should be joined or
mirrored so a user simply chooses which is the most comfortable portal
(for them) to an identical knowledge base. Personally I would be really
reluctant to fragment the community along forum/email lines and
recommend staying away from a wholesale launch of the forum until it
can be integrated with the mailing lists.
[For most of the communities I've participated in, a mailing list is
formed first and therefore has the broadest and most experienced user
base. If the reverse is true then the first phrase would be just as
true if read as "My biggest problem with mailing lists is..."]
My 2 cents.
-matt
Matt Wilkie * Yukon Renewable Resources GIS
http://renres.gov.yk.ca/pubs/rrgis/
