[GRASSLIST:1762] ascii data import
Brent Wood b.wood at niwa.cri.nz
Tue Apr 24 20:07:19 EDT 2001
As a new GRASS user, I'm trying to get some of my data into GRASS so I can
use it.
The documentation I have describes the commands to use, but not the file
formats I need to use for the commands to work.
Typically I have three data formats, each line of which is as below:
 X Y     ascii trackline data (longitude/latitude) defining a polyline
 X Y X Y data defining the start & end points of simple line features
 X Y Z   data defining points with a location and value, such as altitude
         or temperature
 I can reformat these as required, if I knew what formats are required.
 Can someone please suggest an approach to getting such files into GRASS
Brent Wood
