[GRASSLIST:2759] Re: another wish error
Glynn Clements glynn.clements at virgin.net
Thu Dec 6 13:06:51 EST 2001
Noriel Christopher C. Tiglao wrote:
> I've located the wish program and made the appropriate links, however,
> it seems that I've got a more serious problem my way. Upon running GRASS
> is TclTk mode, I get the following error messages from the console:
> ld.so.1: wish: fatal: libX11.so.6.1: open failed: No such file or
> directory
> ERROR: Invalied return code from gis_set.tcl
If you are using pre-compiled binaries, they would appear not to be
compatible with your system. If you compiled GRASS yourself, there is
a problem with your environment (the shared library was found by the
linker but not by the loader).
Glynn Clements <glynn.clements at virgin.net>
