[GRASSLIST:2812] Re: NVIZ problems on Mac OSX
Nick Cahill ndcahill at facstaff.wisc.edu
Thu Dec 20 17:52:41 EST 2001
Many thanks for your explanation. Is the known problem the <el=xxx>
rather than <elevation=xxx>? If so, why doesn't NVIZ work when called
from the command line, with nothing passed to it? Are the errors
"Original error: invalid command name "tkScreenChanged",    Error in
bgerror: invalid command name "bgerror" and "Error in startup script:
invalid command name "tk_menuBar"" fixed in the latest CVS version,
or are they due to something else which can't be diagnosed w/o
compiling the source and seeing what happens?
Thanks,
Nick
At 9:56 PM +0000 12/20/01, Glynn Clements wrote:
>Nick Cahill wrote:
>>  I am unable to get NVIZ to start successfully. Starting from the
>>  tcltk menu, I get an error message "<el=surface> is ambiguous".
>This is a known problem, which has since been fixed (in the current
>CVS version). If an error occurs while initialising Tk, the above
>message is printed instead of a usable error message and backtrace.
>Note: the update won't necessarily solve whatever problem caused the
>Tk initialisation to fail, but it will produce a meaningful error
>message, allowing the underlying problem to be determined.
>Unfortunately, I'm not aware of any updated binaries; you would need
>to build them yourself from the CVS source.
>Glynn Clements <glynn.clements at virgin.net>
