[GRASSLIST:1474] Testing module use
Rich Shepard rshepard at appl-ecosys.com
Tue Feb 20 19:01:24 EST 2001
  I've used v.in.mif (version 5.0beta11.2) to convert the attached vector
file from MapInfo format to GRASS. It appears to work OK, but I cannot get
anything to display on the monitor. I assume that I've done something
improperly, but I cannot see what it is. I also ran 'g.region
vector=claims-map', then 'd.vect claims-map color=white' but that didn't
solve the problem.
  I'd appreciate someone else doing this and, when you see the results in a
monitor, write and tell me what you entered for each option in v.in.mif.
  Here are the specs for the region:
Projection:		stp Nevada (32), Pershing County (27), western zone (2703)
Ellipsoid:		grs80
Datum:			nad83
Units:			meters
North:			853468.62
East:			4641114.06
South:			819043.72
West:			4589016.45
Thanks,
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
              Making environmentally-responsible mining happen. (SM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
 + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
Type: application/octet-stream
Desc:
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20010220/cbb626c9/claims.obj
