[GRASSLIST:1357] Re: Web Mapping
Markus Neteler neteler at geog.uni-hannover.de
Fri Jan 12 11:07:04 EST 2001
On Thu, Jan 11, 2001 at 08:08:56AM +0100, m.malicky at landesmuseum-linz.ac.at wrote:
> Hi!
> Currently I am developing a web mapping tool for GRASS mainly
> with PHP for our biodiversity Database.
> As I am using the CELL driver for generating pictures I have the
> following questions:
> How can I reset the CELL driver ? - changing the vars
> GRASS_WIDTH and GRASS_HEIGHT to another value after using
> the driver gives me error messages.
That's unusual. Here it runs fine. I can change the resolution like
this:
#write the D_cell file:
export GRASS_WIDTH=100
export GRASS_HEIGHT=200
d.mon start=CELL
d.vect ndsgrenzen col=red
d.mon stop=CELL
#look at it:
g.region rast=D_cell -p
d.mon x0
d.rast D_cell
#reset region to location coordinates:
g.region -dp
# next try:
export GRASS_WIDTH=400
export GRASS_HEIGHT=400
d.mon start=CELL
d.mon stop=CELL
#look at it:
d.mon sel=x0
d.rast D_cell
g.region -dp
Works fine and leads to different resolutions.
> What does happen if 2 processes try to access the ressource
> D_cell at the same time ?
Mhhh, no idea, sorry.
> Do I have to write a scedular to avoid ressource conflicts ?
Maybe yes.
> As each process may re- g.region the GRASS-database, do I have
> to lock this ressource also ?
*Probably* yes as the current settings are used.
Maybe this is a little help,
 Markus Neteler
