[GRASSLIST:1383] Re: import TIGER/LINE file
coopl coopl at ippc2.orst.edu
Sun Jan 21 20:37:24 EST 2001
Lu,
There is a shell script called tig.feat.sh written by Malcolm Williamson
I dont see it in my latest version of grass (4.3) but I do have it
available on an older version (4.1, script is dated 4/8/94).
I once used it (~ 5 years ago) and I remember it worked back then.
Len
an lu wrote:
> Hi,
> I want to import TIGER/LINE file into grass. I have
> used  v.in.tig.basic t1=name1 t2=name2 out=newmap.  i
> got the new vector file "newmap", and then i run the
> v.support in order to query the newmap with mouse. the
>  problem is :
>    the road i want to query is not labelled, the query
> result is just a TLID, not the feature name, such as
> I-95 or I-195, as i expected.
>    when i want to edit the category (choose "2" during
> running v.support), i was told the category files were
> missed.
> I also try the v.in.tig.lndmk, when i select the kind
> of map as "area" or "site", it works well. but when I
> selected  "line", it give the error information:
> "syntax error near the spheroid=[n",  although it is
> not required to specified spheroid.
> so i can not the get the vector map with road name
> labelling from the TIGER file.
> i used GRASS 5.0 in redhat 6.2.
> Any help appreciated.
> Lu.
Leonard Coop
Research Associate
Entomology Dept & Integrated Plant Protection Center
2046 Cordley
Oregon State University
Corvallis OR 97331-2907
Phone 541-737-5523
Fax   541-737-3080
http://osu.orst.edu/dept/entomology/coopl
