[GRASSLIST:2163] Re: nviz not working on rh6.0 with grass5.0pre
Glynn Clements glynn.clements at virgin.net
Thu Jul 26 03:17:28 EDT 2001
managing trustee wrote:
> i'm using grass5.0pre (downloaded binaries) for linux (redhat6.0).
> i'm having a problem using nviz. the message that appears is:
> /opt/grass5/etc/nviz2.2/NVWISH2.2: error while loading shared libraries: libtk8.3.so.1: cannot open shared object file: No such file or directory
Either you don't have the correct version of Tcl/Tk installed (that
NVIZ binary will only work with Tcl/Tk 8.3), or the Tk library is
named differently (although I doubt this; RedHat's Tcl/Tk RPMs
generally use the versioned names, e.g. libtk8.3.so).
Glynn Clements <glynn.clements at virgin.net>
