[GRASSLIST:1636] Re: display several maps
Justin Hickey jhickey at hpcc.nectec.or.th
Mon Mar 19 21:05:22 EST 2001
Hi Julien
julien wrote:
> Hi list,
> I'm working on a project into GRASS which is composed by several
> maps. (raster).
> These maps have been imported into GRASS using r.in.tiff. and
> r.support.
> Each of these maps has the good coordinates. They compose a large
> map.
> But how can I display these maps together in the monitor ?
> Using d.rast -o map1 ... d.rast -o map2 ...is quiet boring when you
> have 10 or more maps !
> I've thought to write a small script to do that but maybe there is a
> module to create a group of maps in a project.
> I've tried to create a new group composed by all these maps but I'm
> not able to display it (the name of these groups does not appear in
> the g.list rast).
I'm not sure what you did to try and group your maps. However, I believe
the command to use to create a single raster map out of several smaller
maps is r.patch. Please see the html documentation that comes with Grass
(starting point is documents/index.html). Select the raster commands
link and then the r.patch link. Please note that there are tips in the
"Notes" section that may be useful to you.
Hope this helps.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
