[GRASSLIST:1846] Re: ps.map - 'text' command
Radim Blazek Radim.Blazek at dhv.cz
Wed May 16 01:19:35 EDT 2001
mlennert at club.worldonline.be wrote:
> Hello,
> I'm trying to use linebreaks in the 'text' command in ps.map, but I just
> can't get them to work.
> On the html-manual page it says that putting '\en' into the line will
> produce a linebreak. I've tried this and
> it will just write 'en'.
> The manual then goes on to give an example (e.g. USA\|\enCERL). So I tried
> to put in '\|\' en instead of \en, but this just produces a '|en'.
> Could someone enlighten me ?
> Moritz
That is bug in manual, it should be '\n' as usual in C and others.
Unfortunately text is always justified to the left.
I din't fix that in repository because I cannot somehow connect (my
problem here probably), I'll fix later from my home.
Radim
