[GRASSLIST:1852] help on d.mon
=?UNKNOWN?Q?Ant=F3nio?= Torres grass at portugalmail.pt
Mon May 21 10:05:14 EDT 2001
I have recently installed Grass 4.3 running on Linux and I was trying to
display a monitor with d.mon . First, with g.region, i defined the default region for the monitor (default_win).
Then i defined x1 as the start and the select monitor. When i launch tcltkgrass the monitor x1 appears but the following error also appears:
Graphics driver [x1] started
ERROR: region for current mapsets is invalid
<projection field missing
run "g.region"
Problem selecting x1. Will try once more
run "g.region"
When i apply for a vector or raster display i get the message:
No graphics monitor has been selected for output.
Please run "g.region" to select a graphics monitor.
Can anybody help me with this problem? I'me desperate...grrrrrhhhh!!!
Thanks in advanced
António Torres
www.cea.uevora.pt/lcb
_____________________________________________________________
O e-mail preferido dos portugueses http://www.portugalmail.pt
