[GRASSLIST:1898] Re: postgresSQL interface
Glynn Clements glynn.clements at virgin.net
Tue May 29 14:46:56 EDT 2001
Stefano De Felici wrote:
> I have downloaded the binary version of GRASS 5.0 pre1 and it works fine.
> I have met only two problems. A little one is: the script grass5 is not
> copied in /usr/local/grass5 then you must do it manually.
The "grass5" script should go in /usr/local/bin, so that it is in the
path. Note that /usr/local/grass5/{bin,scripts} shouldn't be in the
default path; these programs can only be run from within GRASS (which
adds these directories to the path).
Glynn Clements <glynn.clements at virgin.net>
