[GRASSLIST:2704] Re: r.thin , where am I wrog?
Markus Neteler neteler at itc.it
Wed Nov 28 12:35:07 EST 2001
On Wed, Nov 28, 2001 at 06:20:07PM +0100, michele.rocc at libero.it wrote:
> Hi,
> I tried to vectorize a simple map:
> ported to pnm(ppm) with the gimp, from a jpg;
> run r.thin, after 5 iterations had a thinned map;
> but running r.line I had the message: not thinned properly...
> do the map have to be  in a particular format to have a properly
> thynned map?
> thanks for help,       Michele.
Hi Michele,
I had the same problem... It seems that r.thin doesn't
write NULL data properly - the zeros are treated as
cells to get eliminated.
I think I have fixed it recently in CVS, can't remember. Can you
try that version and report again?
Thanks,
 Markus Neteler
