[GRASSLIST:2570] Re: grass5 and network connections
giorgio19291 at inwind.it giorgio19291 at inwind.it
Mon Oct 8 15:01:56 EDT 2001
Hi Rich
I have done changes that you said accordly with my machines "A" and "B" and I now can use commands like g.region and r.mapcalc but I can not start Monitors(0-6)  for visualize data. Nviz is OK and I can visualize data.
Any suggest?
My general problem is:
My machine "A" (Pentium III and 256 MB Ram and  little Hard-Disk) is more
efficient than machines "B" (Pentium MMX with 64 MB and  Big Hard Disk to
store data) so I hope to solve more fast my problems of visualization and
calculations if  Grass5 is on "A" and data to read are on "B"? I hope this
is good solution. Can you give me your opinion?
 Thanks a lot in advance
Giorgio.
----- Original Message -----
To: <grasslist at baylor.edu>
Sent: Sunday, October 07, 2001 7:37 PM
Subject: [GRASSLIST:2560] Re: grass5 and network connections
> On Sun, 7 Oct 2001, giorgio19291 at inwind.it wrote:
> >  I have a little private network of two linux machines and want to know if
> >  is possible use grass5 on a computer with data and location stored on the
> >  other computer of my network? (I have tried to mount filesystem where is
> >  my location with smbfs or nfs but I can not open the monitors or set
> >  region in this way).
> Giorgio,
>   You bet it is! That's exactly what we do here.
>   GRASS is installed on salmo:/opt/grass5/ and _all_ spatial data are stored
> on caddis:/usr4/. On caddis, in /etc/exports/ are the lines:
> /usr2   192.168.55.0/24(rw)
> /usr3 192.168.55.0/24(rw)
> /usr4 192.168.55.0/24(rw)
>   This means to export the /usrX file systems to the entire network (our
> private, class C network) in read/write mode.
>   On salmo, in /etc/fstab are the lines:
> caddis:/usr2            /mnt/usr2       nfs     rw,rsize=8192,wsize=8192 0 0
> caddis:/usr3            /mnt/usr3       nfs     rw,rsize=8192,wsize=8192 0 0
> caddis:/usr4            /mnt/usr4       nfs     rw,rsize=8192,wsize=8192 0 0
>   When I want to run GRASS to work on a project, I cd to
> /mnt/usr4/projects/... (that is, the GRASS ``location" directory), then I
> invoke GRASS5.
>   $GISBASE is /mnt/usr4/projects/. Location could be nevada/, oregon/,
> alaska/ or any other overall location for projects. And mapset would be the
> specific project directory. I keep my PERMANENT files in the location, but
> separate from each mapset.
>   Works for me on my Red Hat 6.2 network. YMMV.
> Rich
> Dr. Richard B. Shepard, President
>                        Applied Ecosystem Services, Inc. (TM)
>             2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
>  + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
>                          http://www.appl-ecosys.com
