[GRASSLIST:2606] re:g.select.pg
Sjors jkwast at home.nl
Thu Oct 25 14:13:38 EDT 2001
Well the problem is as follows. When selecting g.select.pg (I"ve wrote
it down wrong the first time) within GUI, I can fill in servername and
database. Then I get the following statement:
Couldn't execute g.select.pg no such directory or program.
This happened with compiling and the install of the new binaries.
With ./configure --with-postgresql-includes=/usr/include/pgsql is
doesn't seem to find the header file. Does compile won't install. I've
got the binaries now. Everything seems to be oke (RedHat7.2).
Well I've found the answer. The command is located in
/usr/local/grass5/etc/bin/cmd. This doesn't seem to be in the path.
I've not yet tested in GUI form. only from console.
Thnx anyway,
Sjors
