[GRASSLIST:2396] Re: r.in.gdal problem
Glynn Clements glynn.clements at virgin.net
Wed Sep 5 02:52:39 EDT 2001
JWDougherty wrote:
> I am attempting to import DEM files to a new location.  The files have been
> converted from SDTS format to binary DEMs using SDTS2DEM.  I am trying to
> bring these into Grass using r.in.gdal, but I am receeiving an error message
> announcing that r.in.gdal is unable to initialize the GDAL bridge and to
> check the installation of libdgal.  I am running GRASS 5.0.0pre1.  I have
> compiled on my system under SuSE linux 7.2.  Aside from the fact that NVIZ
> will not compile, I received no errors during the compile.  My system is a
> PII 350 mHz system with 20 GB of hd space for Linux and 385 mb of ram.
> Can someone offer a clue? (Is r.in.gdal the correct module for instance).
You can also use r.in.bin, which doesn't require GDAL.
Glynn Clements <glynn.clements at virgin.net>
