[GRASSLIST:2421] problem selecting x0
Aurelien aurelien at fractals.be
Tue Sep 11 08:33:07 EDT 2001
Hi again,
Trying to debut in grass, I'd want to start a monitor (I think that's
mandatory if I want to see anything on-screen, isn't it ?).
So I did d.mon, then selected x0 as a monitor to start.
First, grass told me that /usr/local/grass5/dev/fifo.1a wasn't
available, so I checked into /usr/localgrass5/etc/monitorcap, where I
saw that a [...]/fifo.1b was also needed. I tried again, without
success, then I created manually 2 empty files named fifo.1a and fifo.1b
in /usr/local/grass5/dev, but now the message is:
Sorry, </usr/local/grass5/dev/fifo.1a> is not a fifo file.
What is a fifo file ???
Thanks for your precious help,
Aurélien
