[GRASSLIST:3443] RE: r.le.setup
William L. Baker BakerWL at uwyo.edu
Thu Apr 4 12:47:17 EST 2002
Hello,
The region map must be a raster map, not a vector map.
You can turn the vector cover into a raster map using
the v.to.rast command.
Bill Baker
r.le author
Univ. of Wyoming
-----Original Message-----
From: dnogues at ipe.csic.es [mailto:dnogues at ipe.csic.es]
Sent: Thursday, April 04, 2002 9:18 AM
To: GRASSLIST at baylor.edu
Subject: [GRASSLIST:3442] r.le.setup
Hi grassmen and grasswomen
I have another question related to r.le programs. After triying
different ways
i can't put a previosly created vectorial cover , a 10x10 km mesh with
80
squares, as sampling regions. When im reading r.le manual, I understand
that
this is possible: extracted from manual at page 8 "the user can use
r.le.setup
to draw regions, or any existing map of regions can simply be used
directly".
I cant find the correct way to do it. Anybody can help me?
Thanks in advance.
Delegacion del CSIC en Aragon. Servicio de Correo Web
http://www.dicar.csic.es
