[GRASSLIST:3473] Re: Importing e00 files
Radim Blazek blazek at itc.it
Tue Apr 9 02:01:11 EDT 2002
On Tuesday 09 April 2002 01:31 am, Glynn Clements wrote:
> Terry Duell wrote:
> > I am running Grass5pre2, and have an Arc/Info e00 file which I would like
> > to import to a lat/lon location/mapset.
> > I was under the impression that there was an import tool to do this but
> > when I looked it was nowhere to be found. All I found was the v.in.arc
> > tool which is for the 'ungenerate' format, which I think is different.
> > Can a kind soul please advise how I should go about importing this data?
> Try m.in.e00.
If you have e00 with areas, I would recommend, to set map scale (in v.digit)
to some big value (1:1), and run v.support again. Otherwise map threshold is
too big, and v.support may fail even on clean data.
Radim
