[GRASSLIST:4298] r.in.gdal kap files
Kevin Slover kevin.slover at noaa.gov
Fri Aug 16 11:47:30 EDT 2002
I am attempting to import a Ver3.0 Kap file, and am getting an error:
ERROR 1: Failed to find required RGB/ or BSB/ keyword in header.
I did read that gdal does support ver 3.0 kap files.  I can see bsb in
the header (bsb/na=).  I am using gdal 1.7, however, if I do a ldd on
r.in.gdal, it is unable to locate libgdal.1.1.so.  Is this maybe the
problem?
Thanks..
LTJG Kevin Slover, NOAA
GIS Specialist/Meteorologist/Oceanographer
Tropical Prediction Center/Technical Support Branch
11691 SW 17th Street Miami FL 33165
(W) 305-229-4456  (F) 305-553-1264
