[GRASSLIST:5195] Re: s.in.ascii
Michael Ash mash at econs.umass.edu
Mon Dec 9 10:28:22 EST 2002
Perhaps you need to include the "d=3" option to indicate three dimensions (two dimensions in the default).
"The parameter d allows to specify that more than 2 dimensions will be imported.  Otherwise the third (or further) column in input file is treated as attribute."
s.in.ascci sites=mysites input=/home/user/my_ascii_sites d=3
Use "man s.in.ascii" for details.
Quoting "michele.rocc at libero.it" <michele.rocc at libero.it>:
> Hi,
> inporting  points data with with s.in.ascii i found a strange behavior,
> points are X Y Z format, where Z is height in this case.
> The value i found in the imported file is not height, but a progressive
> number, this looks strange, is there a particular way to import from
> ascii files to maintain the original value?
> thanks, Michele.
