[GRASSLIST:5205] Re: v.line2poly
John Gillette JGillette at rfmd.com
Tue Dec 10 12:01:29 EST 2002
There is also v.build.polylines type=area
or v.alabel ?
> On Monday 09 December 2002 11:15 am, Dragos Lipan wrote:
> > Found in my distribution a v.line2poly.
> > I'm not sure if is only contributed or is a basic module.
> > Trying to convert a line vector to a poly one, i noticed
> that only few
> > (20%) of the expected poligons were generated.
> > How can I find some more info about v.line2poly.
> > And even more, how can I "build poligon topology" (as Esri name the
> > process) from a line vector using Grass?
> I do not know v.line2poly, but v.line2area may be used for this.
> Polygons are build by v.support module.
