[GRASSLIST:5213] RE: g.region help
Eric G. Miller egm2 at jps.net
Tue Dec 10 22:59:02 EST 2002
On Wed, Dec 11, 2002 at 12:19:11AM +0000, Glynn Clements wrote:
> John Gillette wrote:
> > A quick check of main.c for r.in.arc looks like it is supposed
> > to set the "active region" from information in the header
> > of the input file.  It also uses the number of rows and columns
> > from the header to read in the data.
> > Are you sure the raster file size changed?
> > John
> > (Can a developer check me here?)
> r.in.arc sets the imported map's region from the file; it doesn't
> change the current region.
Which is as it should be.  I think the OP is letting d.rast fool
him ;-)
"...the plural of anecdote is [not?] data."  - attrib. to George Stigler
