[GRASSLIST:5249] Re: install-grass51 No rule to make target `bitmap.c'
Glynn Clements glynn.clements at virgin.net
Sun Dec 29 11:10:10 EST 2002
Piero Cavalieri wrote:
> >make[2]: *** No rule to make target `bitmap.c', needed by
> >`OBJ.i686-pc-linux-gnu/bitmap.o'.  Stop.
> Why a  .c should be a target?
If a dependency doesn't exist, make assumes that it is meant to be
generated by some other rule. If it can't find such a rule, then you
get an error like the one above.
Glynn Clements <glynn.clements at virgin.net>
