[GRASSLIST:3099] Re: importing using r.in.gdal
Ben Logan ben at wblogan.net
Wed Feb 6 06:18:33 EST 2002
Clint,
I'm using 5.0pre2 on Redhat 7.1, so maybe this has changed between
versions, but with the version of r.in.gdal that I have (I believe it
is 1.1), the "output" parameter is a map name, not a pathname.  If you
want to then convert the map to an image format like PNG, you run the
appropriate output program like r.out.png.
Try something like this
GRASS:~> r.in.gdal input=maps/8087CATD.DDF output=test
If that succeeds, you can run
GRASS:~> r.out.png input=test output=/tmp/testout.png
Hope this helps,
Ben
On Wed, Feb 06, 2002 at 02:44:32AM -0600, Clint Miller wrote:
> I'm a grass newbie and am trying to import USGS DEMs.  (Yes, I've seen the
> previous post ;)  I'm running RH 7.2-i386, grass5.0.0pre3 and I've tried both
> gdal1.1.5 and 1.1.6.  Both grass and gdal have been compiled from source and
> the spearfish sample data works great with everything installed.  I've been
> wanting to try Grass for years and I must say it rocks.
> I must be doing something stupid with:
> GRASS:~> r.in.gdal input=maps/8087CATD.DDF output=/tmp/testout.png
> This segfaults in libgdal1.1.so everytime.  I've tried all the writable
> formats defined in the gdal docs.
Ben Logan: ben at wblogan dot net
OpenPGP Key KeyID: A1ADD1F0
Few things are harder to put up with than the annoyance of a good example.
		-- "Mark Twain, Pudd'nhead Wilson's Calendar"
