[GRASSLIST:2861] Re: Compilation problem w/5pre2: flate.c (zlib?)
nsmith at holycross.edu nsmith at holycross.edu
Sat Jan 5 14:14:52 EST 2002
On Saturday, January 5, 2002, at 12:25  PM, Glynn Clements wrote:
> nsmith at holycross.edu wrote:
>> I'm failing to complie GRASS5pre2 on YellowDogLinux.
> It's quite possibly related to the fact that one of the PostgreSQL
> headers is called "config.h". Try configuring without using
> /usr/include for any of the --with-includes or
> --with-[whatever]-includes
> switches.
> If that doesn't work, you'll need to use a more recent version of
> GRASS (e.g. a CVS snapshot). GRASS' own src/include directory should
> take precedence over all system include directories in recent
> versions.
> Glynn Clements <glynn.clements at virgin.net>
This was exactly the problem.  I misread or was misled by the INSTALL
doc and used the generic --with-include to set the postgres include
directory:  running configure with a specific --with-postgres-include
and nothing else cleared up the problem.
Thanks for the quick help!
Neel Smith
