[GRASSLIST:2862] Re: GRASS File structure for projects
Eric G. Miller egm2 at jps.net
Sat Jan 5 15:07:56 EST 2002
On Sat, 5 Jan 2002 18:48:47 +0000, Glynn Clements <glynn.clements at virgin.net> wrote:
[snip]
> > In particular, I would like to import a DRG tiff file, but can't seem to
> > get GRASS to do this. It goes through the motions of importing, but the
> > map does not show up in the monitor.
> I'm not familiar with "DRG" TIFF files (I'm a computer programmer, and
> have only recently started working with GIS). In general, TIFF files
> can be imported with r.in.tiff or r.in.gdal.
DRG = Digital Raster Graphic.  It's a generic term, often used to indicate
scanned paper maps.  Nothing special about them.  Usually 8-bit color
images with georeferencing (TIFF World = affine parameters).
Most likely, you don't "see" the raster because your region settings don't
match/encompass the imported raster.
g.region rast=<your drg>
Eric G. Miller <egm2 at jps.net>
