[GRASSLIST:2927] Re: fifo problems with GRASS 5.0.0 pre3
Glynn Clements glynn.clements at virgin.net
Thu Jan 17 14:36:23 EST 2002
Ilja Schneider wrote:
> I just compiled GRASS 5.0.0 pre3. After solving little problems with
> permissions on some scripts and modules I created a new location and
> imported a tif file without any problem. But as tried to start a monitor
> d.mon threw following message:
> "Usage x0 [-] "input_fifo output_fifo" [nlev]
This suggests that you aren't using the pre3 version of the monitor.
The error message has changed to:
	Usage: /path/to/XDRIVER <name> [-] "input_fifo output_fifo" [<nlev>]
Ensure that any previous version of GRASS is removed (or moved out of
the way) before installing pre3.
Glynn Clements <glynn.clements at virgin.net>
