[GRASSLIST:2987] RE: Vector manipulation
Beaudry Charles (NORANDA) BeaudryC at normin.com
Thu Jan 24 10:09:25 EST 2002
 Emanuel,
> I've got some difficulties to find the operations that permits to
> display
> a vector with different colors for vectors that have a
> specific value on
> a field.
Don't look you wont find any.  You may be able to color the vectors by hand
if you export the vectors to XFig.  Otherwise you will need to wait for the
new vector model to be published in the future.
Alternatively you may convert the vector layer to a raster file using the
You can always use the field value as an attribute and then you may color
the rasterized lines.
> I also have some difficulties to find informations that permits me to
> build and
> print a map with scale, legend, graticules, etc.
For this no problem.  You can use the ps.map for this but read all the
documentation because you need to select the postscript driver first.
> Cordialement
> Emmanuel Poizot
> CNAM/INTECHMER
> B.P. 324
> 50103 Cherbourg Cedex
> Tél : (33) (0)2 33 88 73 42
> Fax : (33) (0)2 33 88 73 39
This message has been scanned by the AT&T Global Network Services Virus Detect Service. Ce message a été scruté par le service Virus Detect des Services de réseaux mondial AT&T.
The file email-body has been scanned by the AT&T Global Network Services Virus Detect Service. ********** Ce fichier : email-body a ??scrut?par le service Virus Detect des Services de r?eaux mondial AT&T.
