[GRASSLIST:3005] Re: how to resize d.mon window?
Emile Snyder esnyder at whitesalmon.net
Sat Jan 26 05:27:38 EST 2002
On Sat, Jan 26, 2002 at 04:15:01AM +0000, Glynn Clements wrote:
> Eric G. Miller wrote:
> > window size during a redraw event.  Apparently, Blackbox interprets this
> > to mean it is a fixed size window.  It appears to be a specific issue
> > with blackbox.  Its too bad, 'cause I like blackbox..
I found a blackbox specific workaround; I specified a keyboard shortcut with
bbkeys to maximize a window using the following line in ~/.bbkeysrc
KeyToGrab(F1), WithModifier(Control), WithAction(MaximizeWindow)
For some reason, using this works on the window even though mouse resizing
doesn't.
> For the record, the specific problem is that the monitor window sets a
> minimum/maxmimum size via the WM_NORMAL_HINTS property, then later
> removes the limit. Certain WMs seem to "remember" the limit after it
> has been removed..
> In case anyone who experiences this problem wishes to report it to the
> developers of their WM, I would suggest sending them the output from
> "xprop", and pointing out that the window can't be resized when the
> WM_NORMAL_HINTS property seems to suggest otherwise..
Thanks for the tip.
> As for specifying the monitor size at startup, use the environment
> variables XDRIVER_WIDTH and XDRIVER_HEIGHT, e.g..
> 	XDRIVER_WIDTH=640
> 	XDRIVER_HEIGHT=480
> 	export XDRIVER_WIDTH XDRIVER_HEIGHT
And for this one.
-emile
> Glynn Clements <glynn.clements at virgin.net>
