[GRASSLIST:3009] Re: Importing TIFF Images
Mon Jan 28 09:27:51 EST 2002
Ben wrote:
 > So I saved the DOQQ as TIFF with a scale of 1:16, and tried to import
 > it with r.in.gdal.  Here's what r.in.gdal said:
 > ERROR: Projection of dataset does not appear to match current location.
 > cellhd.proj = 0 (unreferenced)
 > You can use the -o flag to r.in.gdal to override this check.
 > Does this mean that the TIFF is not georeferenced?
Ben,
This does mean that r.in.gdal believes there is no georeferencing on your
file.  If you ftp a sample to gdal.velocet.ca/pub/incoming and drop me a
line I will look at it and see if anything is being missed.
Best regards,
