[GRASSLIST:4026] Re: gdal on cygwin
Glynn Clements glynn.clements at virgin.net
Thu Jul 4 12:42:37 EDT 2002
Thomas Dewez wrote:
> How I should proceed to get gdal libraries up and running with Windows XP
> running Cygwin and GRASS5.0pre3 ?
	./configure --with-gdal ...
The --with-gdal switch should force r.in.gdal to be linked directly
against the GDAL library, rather than loading it dynamically. I
haven't tried it on Cygwin, so you might have to modify Gmakefile
manually (gbgetsymbol.c and gdalbridge.c are unused when linking
directly).
Glynn Clements <glynn.clements at virgin.net>
